Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3238 Questions View all
What are the circled parts on the pictures are called?
Please tell me what the circle parts are called, and if there needed thanks
Add a comment
Chosen Solution
akshay patel, see it this works for you.
SP1_RF SPRING-UPPER-ANT-N90
J11_RF MM8030-2600RK0 RF Connectors 11GHz 0.07ohm SWG Type Connector available [ http://www.mouser.com/ProductDetail/Mura...|right here]
L8 is an inductor. It does have values of 800MHZ-100MA-27PF 0603 . You should find it either at Mouser.com or Digikey.com.
C485 is a capacitor 1UF 10% 6.3V in a 402 package. Again, you should find it at the before mentioned places.
L8 and C485 are part of your VGA CAMERA circuit
Total cost for the parts should only be a few dollars, but to replace it, you will need some good tools and great skills. Your board looks like it took a "bad hit" at L8. Hope this helps, good luck.
Score 2
Comments:
Hi this is great thanks so much
by
Thank you for accepting my answer. Best of luck to you.
by
Yes sir, that looks about right.
by
Add a comment
They're called solder joints, and they probably are needed. Also, I think you may have ripped your battery connector out.
Comments:
No i mean what are the individual components called that go there.
Thanks
by
Add a comment
Add your answer
akshay patel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 297
