Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2970 Questions View all
Sensor doesn't work after sensor/power cable replacement?
Hello,
I replaced the sensor/power cable.
Power button works perfect but no sensor.
I tested with other cables, but no succes unfortunately.
Who can help me?
What can i do?
Add a comment
GIVE TOOLS. FIX FOREVER.
GIVE TOOLS.
FIX FOREVER.
Spread the Fixmas cheer.
Chosen Solution
in my experience if u put a small piece of scotch tape covered in sharpie over the sensors before installing the new screen works for me. its not an issue with cables or anything its because its a different tint of paint on the two little holes.
Score 1
Add a comment
you may have a logic board failure. Check the connector. If it is damaged, you need to replace the logic board unless you are talented in micro soldering.
Comments:
There is no problem with the logic board.
Before the replacement worked perfect and now the sensor doest't work.
I have experience with the iPhone 4 sensor problem. On the iPhone 4 is a sensor sticker the sullution.
Maybe on the 4s to?
by
Add a comment
If multiple cables do not work, it must be a logic board issue.
Comments:
Good news.
I just put my logic board in another iPhone 4s and the sensor works then.
There must be wrong with the cable dan.
by
Add a comment
Add your answer
appledem will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 152
