Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2940 Questions View all
Any way to replace 30 pin with Lightning?
Just to make things easier. Kinda sick of having two kinds of cables. I know it sounds stupid and a simple solution would be to buy an iPhone 5, but that's not really in the cards for me right now.
Is there any way to pull the phone apart and take out the dock connector and put in an 8 pin connector?
Add a comment
Chosen Solution
Sorry, No
The logic behind the older dock connector is not the same as what the Lightning port uses, besides the mating area of your phone is a different size & shape.
Save your pennies for a new iPhone ;-{
Score 2
Add a comment
Lightning uses a special interface chip. So it's impossible to replace
Score 2
Add a comment
To do exactly what you require, you must follow the following steps:
  1. Find an iPhone 5 (doesn't even have to work).
  2. Line both phones up next to each other.
  3. Bring out a very precise cutting instrument (preferably a laser diamond cutter).
  4. Slice of the bottom halves exact same spot.
  5. Combine the iPhone 5 bottom to your phone (preferably using solder or Elmer's Glue).
  6. Congrats! Now you have a hybrid phone!
Add a comment
Add your answer
Timikan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 32
All Time: 1,263
