Model A1174 with 2 GHz Core Duo or Model A1207 with 2.16 or 2.33 GHz Core 2 Duo
212 Questions View all
Display or graphic card dead - what part to change?
My iMac i s a A1207 and the monitor is all black - I have tried to connect an external monitor whit no luck.
The iMac is booting/starting - I can start it in firewire mode and backup my files - no problem.
Score -1
1 Comment
Have you checked the diagnostic LED's? What are the last three digits of your serial number? That way we can identify your computer properly.
by
Add a comment
1 Answer
Chosen Solution
Carl Elon, check the diagnostic LED's :"
Diagnostic LEDs
The iMac has built-in diagnostic LEDs on the main logic board that can help you to
troubleshoot the computer. The LEDs are located to the right of the battery (see photo below).
LED #1
Indicates the trickle voltage from the power supply has been detected by the logic board. This LED will remain ON whenever the iMac is connected to a working AC power source. The LED will remain on even when the computer has been shut down or put to sleep. The LED will turn off only if the AC power source is disconnected or the power supply is faulty.
LED #2
Indicates the main logic board has detected proper power from the power supply when the computer is turned on. This LED will be ON when the computer is turned on and the power supply is working correctly.
LED #3
Note: This LED is not used on systems that have integrated graphics, which includes all configurations of the iMac (20-inch, Early/Mid 2009).
LED #4
Indicates the computer and the LCD display panel are communicating. This LED will be ON when the computer is turned on and video signal is being generated. If the LED is ON and there is no image on the LCD display panel, the LCD display panel or inverter might be installed incorrectly or need replacement.
Here is what Apple suggest:
" 1. Verify boot chime present and fans running when system powered ON. (Reset SMC and clear PRAM if necessary for proper boot up.)
Yes Power ON self test OK. Boot sequence started.
Go to step 2.
No Go to Won’t Start Up.
2. Verify whether image is visible on LCD panel.
Yes Video present. Verify system functionality and return to user or jump to appropriate troubleshooting flow.
No Go to step 3.
3. Connect supported external display. Verify whether image appears on external display when system is booted.
Yes External display detected by system. Video circuitry on logic board functional. Go to Backlight Issue/No Backlight
No Go to step 4.
4. Remove glass panel and front bezel. Do all three diagnostic LED’s turn ON shortly after the system is powered ON?
Yes Internal video circuitry functional and communicating with LCD panel. Go to Backlight Issue/No Backlight.
No Replace logic board. Retest.
Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Carl Elon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 673
