No startup chime, mechanical sound, front led light up for 1 second
MacBook Pro A1260.
I've replaced the HDD with a SSD (Crucial M4), the Apple Battery with a generic one (Novodio) and new RAM (2*2Go)
Everything has been working fine for the past 2 months.
Yesterday I went to work and let the computer on, with power adapter plugged. When I came back at mid day it won't come out of sleep mode. I'm almost sure the power went down in the house so the battery was empty.
I let it charge but now it won't boot.
When I press the power button I do get a mechanical noise, the screen stays black, the front LED light up for about 1 second and then everything stop.
If I try to boot without RAM I've got a loud noise every 3 or 4 seconds.
If I try one RAM slot and then the other it's the same as in the beginning (LED light up for only 1 second)
If I keep power button pressed for 10sec the front led flicker and then goes off.
What else can I try ?
2 Comments
Are you using an 85 watt AC adapter?
by Matt Barnes
Yes. I'm using an 85w Adapter. The official one from Apple.
by jfdoazan
