The Samsung Galaxy S4, model i9505, features a 13-megapixel rear camera, and a 5-inch 1080p display.
526 Questions View all
NFC: This Tag Is Not Supported
Hi, whenever I try to scan my new NFC tags that my sis got me from eBay with my S4, it says "This tag is not supported" on 3 different NFC writer apps! I even tried to scan one outside of any app with the same result! Help?
Score 24
1 Comment
It works. Thanks. :)
by
Add a comment
Most Helpful Answer
Go to swipe menu you get when you swipe the home screen down ( so you can turn on bluetooth and wifi and all that) then turn off nfc tag! It stops the annoying bleeding beeping that drives you crazy everytime you move the poxy thing..................and breathe
Score 16
11 Comments:
Perfecto!; Mine was under settings, 'Connect and Share' NFC - swipe to off position.
by
Thanks so much for your help!
by
Thank you. I even use a galaxy S6 for this issue you solved.
by
This is about the only answer that was right
by
Thank you! You saved my life
by
Show 6 more comments
Add a comment
http://www.themobileindian.com/news/1186...
Samsung's flagship smartphone Galaxy S4 has been incompatible with the first generation TecTiles Near Field Communication tags. Now the company quietly plans to push the TecTiles 2 NFC Tags.
Score 2
1 Comment:
thanks it was driving me mad
by
Add a comment
I get the same message on my main screen when I move the phone. Please let me know what causes it and how to stop it when you know.
Score 2
Add a comment
Thank you! Thank you! Thank you! Thank you!
Was driving me loopy..
Score 2
Add a comment
Thanks for the fix too. But what is nfc tag and how did it turn itself on?
Score 1
Add a comment
How do I fix this when I need NFC on to work my smart gear Watch?
Score 1
Add a comment
Whatis NCF tag I have got
Score 1
Add a comment
i can not use this my nfc tag is not working
Add a comment
my nfc keeps beeping on my samsung galaxy s6 keeps beeping i wanna have it on but i dont want to turn it off what can i do to make it stop beeping
Add a comment
You can just turn off the sound. But the best way is to turn off NFC
Add a comment
What is NFC tags and what is it used for???
Add a comment
I had my hotel card/key in my hand and this kept beeping! I googled the code to figure-out what it was and lo-n-behold, it was the key!!
Add a comment
Add your answer
Jeremy Scalpello will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 13
All Time: 85,716
