2.26 or 2.4 GHz / White plastic unibody enclosure
648 Questions View all
Battery Condition "Replace Now" after replacement.
I replaced the battery in my macbook, connected the power cord and turned it on. The power cord indication light remained green and when I click on the battery percentage it says "replace now."
Score 6
Comments:
my MacBook is new and I just got it yesterday on July 6 2017. When I opened my new MacBook it says replace now. its new, why is my battery asking me to replace my battery???
by
Add a comment
Chosen Solution
hi
please try a System Management Controller (SMC) Reset by following the below link :-
http://support.apple.com/kb/HT3964?viewl...
The fan on your macbook would go high, No need to worry about it with the next restart it behave normal.
Keep us posted with the results. . . .
If you think i answered your question please rate (score) and mark it accepted. :)
Thanks
Score 2
Comments:
Hi gargivarun, I followed the troubleshooting and reset the SMC but, alas, no help. My old battery still works (albeit, poorly) so my guess now is that the battery I got isn't working. I think my next step is returning it and trying a different battery. Thank you!
by
Add a comment
I had this issue with two replacement batteries, tried the SMC reset, PRAM reset, etc. One of the two responded for a little bit (24-48 hrs), but then would fall back into the "replace now" status and the laptop would not stayed on under battery power. The other battery never responded and immediately said "replace now".
Working with support, I received a cross ship of a third battery and it has worked flawlessly - no SMC reset, no PRAM reset, just replaced and powered up and works great.
So, my suggestion is report the issue back to support and get a second (third, fourth...?) sent out to you. Can't say why, but seems there is some percentage of bad apples in the mix.
Note that I used coconutBattery to document the battery situation with replacement #1 & #2 for support. Gives a series of good data points that demonstrates the status with notation of the battery production dates and cycles. When you think you have a good battery, though, make sure you use it for longer than a couple of days before you call it a victory.
Score 1
Comments:
Where did you end up getting your battery from? I bought mine from a reputable eBay vendor, they refunded my money but didn't ask for it to be returned. I need to find one from a source that has working batteries. I checked out the bad one I got with coconut battery and its was manufactured in March 2013 with 8 load cycles, holding 42% charge. Not sure what to do with it now.
by
I purchased mine through ifixit. It was their support that provided the replacements (eventually a working one).
by
I've experienced the same issue as you all have. The replacement battery, in my case a Lizone, did not start the Mac Book and the MagSafe power cord LED was solid green. I contacted Lizone and they immediately sent me a replacement battery and wah la...the MacBook started up :) It was a defective battery.
by
I still have the same issue. My MacBook Pro is still 3months old :( and it's a bad experience :( too bad Apple :( really disappointed :(
by
Just an update to my 11/20/2016 post. The replacement Lizone battery did not extend the battery duration...still only good for about 50 minutes till its discharged. I pretty well have to have the power cable near me at all times.
by
Show 1 more comment
Add a comment
Did you ever get your battery fixed? I'm having a similar issue with a new battery...
Comments:
havin' similar issue did you fix it?
by
Add a comment
I'm having this issue too...help?
Add a comment
I am also having this issue. I just replaced the battery and mine says "Condition: Replace Now." It will not charge, so I have to keep my MagSafe plugged in or the laptop dies. The battery is supposedly at 44% though. Did another new battery help?? I'm still waiting on a reply from the seller to try to return mine...
Add a comment
Add your answer
sammolzahn will be eternally grateful.
Past 24 Hours: 30
Past 7 Days: 204
Past 30 Days: 1,057
All Time: 25,183
