CDMA version of the fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. 16 or 32 GB / Model A1349 / CDMA compatibility.
422 Questions View all
"No Service" constantly after dropping on the ground about 4 feet.
i was just texting, and i dropped my iphone down onto the hard tile, and the only way to power it back on, was to take off the back, disconnect, and reconnect the battery. however, i get about a minute of the "Searching..." for the carrier, then no service, and i have checked the inductors and the connections, everything really seems to be alright, but cannot seem to fix the no service problem. any suggestions?
Add a comment
1 Answer
Chosen Solution
Make sure you set the time and date correct this will sort out the signal plus make sure the antenna connector is seeded correctly its the one with the black wire
Add a comment
Add your answer
Colin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,302
