Why do I have a white screen after replacing lcd and digitizer?
I bought a replacement screen for my ipod touch because my screen was cracked and the right side of the screen was unresponsive. i've fixed several ipod's before and this is the only one to have this problem with. I'm not sure if it's a faulty lcd and digitizer because i've used this seller before but it might. I have triple checked the cables and i'm not sure why i'm having this problem. The ipod won't power on by me pushing the power button or holding the home and power button. it's not in dfu mode. the only way i can see the white screen is if i plug it into the computer and itunes recognize it. Then the white screen shows for a couple seconds then flicks off. I'm not sure if i'm missing something. i have tried to ground it but not to the computer to a wall plug in for the ipod. I'm up for any suggestions and i'm really close to buying another replacement screen but only after i've exhausted every option. Thanks for your patience.
Add a comment
Chosen Solution
Hard reset hold the power and home bottom at the same time til the screen reboot and let go of the buttons.. This happens when the screen is disconnected and the power some how got turned on
Score 2
Comments:
thanks but i tried that several times and that didn't work.
by
Add a comment
get a loupe or magnifying glass and check the little pins on the cable and female connector on the board to see if any accidentally got bent.
Score 1
Comments:
a couple pins did get bent unable to see with my eye. thanks
by
Add a comment
Add your answer
christian white will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 922
