Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Wont charge or turn on?
My iphone 3gs was on the charger all day because i forgot about it but when i took it off it wouldnt turn on. When i tried to turn it on the symbol of the charger and red battery came up then after that it just wont turn on.... What could it be??
Score -1
Add a comment
1 Answer
Chosen Solution
jess, this could be caused by a bad battery. It is easily possible that this battery is at the end of its lifespan, and not longer holds a charge. Replace the battery, check your cable, use another cable, and clean your dock connector with a bit of isopropyl alcohol, a soft brush, and a few puffs of compressed. I'd definitely start with that, use this guide to work on it and the battery is available right here as well as many other places. Hope this helps, good luck.
iPhone 3GS Battery Image
Product
iPhone 3GS Battery
$14.99
Score 2
1 Comment:
Thank you :)
by
Add a comment
Add your answer
jess will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 262
