Model No. A1367 / 8, 16, 32, or 64 GB capacity
1283 Questions View all
Is there a hard drive in this, or a solid state?
Is it possible to change a 8gb iPod touch into a 32gb or 64gb? I am an electronics technician with 12 years experience, could I just change the flash memory chip? Or are there other supporting components, ie. capacitors and resistors in the circuit that would need to be added or changed?
Add a comment
1 Answer
Chosen Solution
laotto70, nope you can not. sorry. All the information is stored on a NAND flash memory BGA chip. Of course when you say "could I just change" and you mean a complete reball, with proper stencils, balls and a proper NAND IC then yes you can. :-) Take a look at the teardown on here for a better visual. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
Lawrence will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 423
