Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1409 Questions View all
Can I Upgrade my logic board?
I have a MacBook 2.0GHZ MA700*/A, and I would like to change my logic board to my other MacBook's 2.16Ghz(MB062*/A) one.
Will it be possible?
What other parts can be shared between this 2 models. Thank you.
Add a comment
Chosen Solution
Perhaps Ben can help us here. I looked at both models in Mactracker and found no difference except CPU speed. How ever this doesn't necessarily indicate compatibility for a swap. Why would you want to do this? Is there a problem with the newer unit? If that's the case you may want to remove the board from the donor unit and hold it near the other unit. What you would be looking for is do the cables match--are the connections the same--do the ports line up in the case? If everything checks out and you feel froggy go for it. To be on the safe side I would either wait for Bens answer or email him at ifixit for an answer. Ralph
MacBook Core 2 Duo
Score 1
Comments:
Answer to your second question it looks like most parts would work in the other unit. Ralph
by
If you want to email Ben--http://www.ifixit.com/Info/contact
by
Add a comment
It's just not feasible to change your logic board. If you look at the cost alone, it's worth buying a whole new computer, with everything updated.
If you get past the cost, the work should be enough, unless you're a very experienced and talented technician with a lot of time on your hands it isn't a feasible repair.
Add a comment
Add your answer
Ivan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,760
