Antenna Switch PCB on Motherboard
How to exchange the Antenna Switch PCB on the Motherboard?
This is soldered or glued?
joerg, if you are talking about the Antenna Signal Module also called ""cellular Interconnection Flex, cable" than yes, it is solder. A good soldering iron with a fine tip, and good skills are a must for this. Hope this helps, good luck.
Any link for part ? Nothing on ebay as I can tell ?
will this work for iphone 5c?
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,292
