Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
555 Questions View all
Is PC2-6400 compatible with EMC2133 iMac?
Hello!
I wanna upgrade my iMac EMC2133 original configuration and add some RAM. I found some ram stick of DDR2 PC2-6400, and those are usually backwards compatible in most mainboards, but i don´t know if this is the case. I know that it uses 667 ram, but it will work with 800Mhz ram?
Thanks!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Won't work you have the wrong machine for that type RAM. You'd need a 2210 iMac8,1 for the RAM you found.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Also, this site works EXTREMELY well for specs on all Macs and iDevices.
http://everymac.com/ultimate-mac-lookup/...
You can look up each Mac, down to serial number and then open a large list of specs.
For your iMac EMC2133
http://everymac.com/systems/apple/imac/s...
Scroll down a bit and you will find this info:
RAM Type: PC2-5300 DDR2 Min. RAM Speed: 667 MHz
Details: Supports 667 MHz PC2-5300 DDR2 SDRAM (200-pin SO-DIMM).
Standard RAM: 1 GB Maximum RAM: 6 GB*
Details: 1 GB of RAM is installed as a single SO-DIMM module.
*Apple officially supports 4 GB of RAM, but third-parties have been able to upgrade the system to 6 GB of RAM using one 2 GB and one 4 GB memory module.
In the US (and many other countries), site sponsor Other World Computing sells memory -- as well as other upgrades -- for this iMac.
In Canada, site sponsor The Mac Market sells memory and other upgrades for this iMac.
In Australia, site sponsor RamCity sells memory and other upgrades for this iMac.
In Southeast Asia, site sponsor SimplyMac.sg sells memory and other upgrades for this iMac.
Add a comment
It does work. I found confirmation of this on a different site and have just installed some. Works perfectly.
Add a comment
Add your answer
Joaquin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 1,243
