Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1409 Questions View all
How do I repair on/off button?
I have the early 2009 revision of the A1181 MacBook.
I live in secondary city in Brazil. Not a lot of Apple expertise here.
Local repair shop says that on/off switch is bad, and I need a new keyboard. But, they cannot find parts to repair
What can I do?
Jim Peebles
jgpeebles@msn.com
Add a comment
1 Answer
Chosen Solution
Are you certain its just the button?
There's a lot of circuitry involved on the top case/keyboard from the button (basically two just foil strips) to the ribbon connector which carries power to track pad, function keys etc.
Did you open the case yourself? Many amateurs pull the male connector right off the logic board when opening a MacBook for the first time!
So purchasing a top case/keyboard replacement could solve the problem, but if it's more than simple damage to the "on/off" button that's no help.
Have you looked inside? Can you compare what you see to the guide?
Good Luck,
N.
Score 3
Comments:
+ Ralph
by
Add a comment
Add your answer
James Peebles will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 811
