Backlight isn't working at all
I've read some other guides of people with similar issues but none of them are exactly the same. The backlight on my macbook is completely broken. It won't flicker on or light up no matter what I do. I've tried decreasing the brightness and bringing it back up, I've tried resetting the PRAM and taking out the battery, and I've tried messing with the energy saver preferences but none of it helps.
The computer itself works fine - if I shine a flash light on the screen I can see my desktop and I've been able use the internet and do everything I normally do.
A couple of months ago, I replaced the inverter cable because the backlight would go off unless I kept the screen at certain angles. The "surgery" went fine and the backlight worked great for awhile but stopped working literally overnight (watched an episode of Dr. Who that night, wouldn't work the next morning). I can't think of any other relevant information but I'm happy to answer any questions about the system. Thank you in advance for your help!
Add a comment
1 Answer
Chosen Solution
The screen going dim when at certain angles would be a problem with the inverter cables, not the inverter. Did you replace the cables? Can you still see the desktop dimly or is it totally gone?
Score 1
I think you misread my post. The screen going out at certain angles was a problem with the inverter cable that I fixed already. I included it because I thought it might be relivant information to the problem I'm having now, that is that the backlight wont come on at all.
The desktop is still there, I can see it if I shine a flashlight on the screen.
Add a comment
Add your answer
etj8864 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 135
