Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3237 Questions View all
Can I use this to solder a logic board on my iPhone?
Sorry for my english, but can i use this to solder things on the logic board on a iPhone?
Portable Soldering Iron Image
Product
$19.99
Add a comment
Chosen Solution
aaronlitton, depends on what you want to solder on your board. There is not a lot of room on the board and that particular tip might be a bit big. Otherwise, yes, you can use this tool just like any other soldering iron. Hope this helps, good luck.
Score 1
Comments:
thank you :)
by
Add a comment
Yes,but we have to be very careful about the other components and wires on the circuit board because this iron emits a lot of heat .While soldering a particular component we have to be quite careful about the wires on the circuit board, otherwise it may melt away.Keeping in concern about all these this soldering iron is a must for every repairs and for every electronics repair enthusiast.
Add a comment
Add your answer
krihau12 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 389
