Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3256 Questions View all
After battery replacement with iFixIt battery, phone will not turn on.
About 1 week ago, I ordered a replacement battery from iFixit. after I put everything back together, the phone screen is not working.
The phone vibrates when it is first plugged in, and my computer recognizes the iPhone. Message from iTunes - restore the screen has the look like the restore is happening and the iTunes screen reads waiting for iPhone
However, the screen shows restoring. I opened it up again and double checked that every single connecter was connected and plugged in.
I let the battery charge back up over 8 hours on my spare laptop while I went to work when I returned iTunes message was waiting for iPhone
I plugged the phone into the wall, the phone screen won't turn on at all. It is recognized with the laptop but never leave the screen waiting for iPhone
Score 1
Comments:
mudiwalove, "did you see the two pictures I uploaded " those images are not here. Check this guide Adding images to an existing answer to add images.
by
Add a comment
1 Answer
Did you go any further than just disconnecting and replacing the battery when you did the repair? What can happen frequently with Iphone repairs on the 4 and 4s is that the lcd cable can just simply come loose or not be connecting properly. Almost every time someone comes to me after a repair with a blank or black screen but the phone is on, I just disconnect, clean, and reconnect firmly the lcd cable. Let me know if this helps at all.
Comments:
did what your suggested and got the same results...did you see the two pictures I uploaded
by
I just upload the pictures...thanks
by
Add a comment
Add your answer
mudiwalove will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 262
