Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3221 Questions View all
replaced battery,turns on only when connected to power&no signal
hi,
recently i tried to replace my iphone battery while doing that the new battery connecter clip broke up and i installed my old previous battery which i was using.after that my iphone dint not turned on and when i tried to connect and charge, it turned on with no signal and when i removed the power supply of the charger its again off.what is the solution for this .
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
If the clip is broke on the mother board it will need soldered best bet is to buy a new battery. For the service just make sure time and date are correct!
Score 1
Add a comment
Add your answer
vinay will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 102
