Repair and disassembly guides for HP printers.
1090 Questions View all
How to turn off calibration on an HP color LaserJet 2605dn?
I just got this printer and I did get it going, and it's a nice printer, except one feature I never liked on these HP color lasers, and want off
Color calibration if this unit is idle
It wastes toner, and makes toner go faster, so I want it off
Is there a way to do this? I also have it set to ignore the cartridge levels and I can decide if a toner is low or empty, not the printer
Add a comment
Chosen Solution
Hi nick,
Unfortunately calibration can't be turned off from what I know, but you can change a setting so it only does a calibration every so often, depending on the model of your printer depending settings that you can change it to.
Have a look through your printer settings for *Calibration Timing* and see if you can change it to a different time, for example once a week.
Hope this helps.
Thanks Jordan.
Add a comment
Try this also for empty cardriges:
There is an override in the menu. So open the Menu; Configure Device; System Setup; Replace Supplies (down arrow 9 times); Override at Out.
Add a comment
Add your answer
Nick will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 11,459
