I dipped my iPhone 4 in water now it won't turn on?
I have IPhone 4S and I dipped it in water I've put it in rice for an hour and it still won't turn on and I need It today what shall I do ?
Claire, since it did have an immersion the first thing I suggest doing is to not longer try to turn it on or charge it. It is easily possible that you are shortening out parts on the logic board i.e. the power management IC. If anything, disassemble your phone using these guides. Once you have that done, clean your phone with high grade isopropyl alcohol and this guide. It was written for a 3g but all the points are valid for your phone as well. Once its clean, replace the battery and re-evaluate for further (if any) damage. Hope this helps, good luck.
do not try and turn it on! it can cause damage
open you iPhone, take the logicbord out. check and clean it. then dry it.
reassemble and try to turn it on
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 574
