Water Damaged iPhone 4S-32GB
Hi
My Iphone 4S-32GB was dropped in water , am not able to on it back.
Is it possible to retrieve the data.
rgds
Hi
rgds
Visa, water damage seems to be one of the most common damage lately. You are not the only one that this happens to. There is no real DIY'er way of getting any data from the NAND chips. You would have to have an IC reader and the proper software to get that accomplished. You can try some of the professional forensic labs that specialize in this type of recovery. Those are of course very pricey. Or you could try and see if you can fix your phone. "The first thing I suggest is that you disassemble the phone using these guides. Then clean the phone with +90% isopropyl alcohol. Use this guide to clean it. Make sure to clean all the connectors and cable ends. After you have everything properly cleaned, replace the battery Reassemble your phone and re-evaluate. If you do not clean your phone, you could get corrosion failure later on. I would also no longer try to do anything with the phone until it is cleaned, you are running risk of further damaging it. Hope this helps, good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 287
