Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1500 Questions View all
Radio failure? Error 23 when restoring
I have two iphone 3GS on my work bench I just can't get working.
I'm thinking it's a logic board failure but as I have two at once I wanted to run it by the masses.
Hardware wise they all seem ok - screens power on, backlights etc - they're stuck in a restore loop but whatever I do when trying to restore (DFU mode or standard) I get error 23.
Looking at the iphone updater logs the last few lines for both read:
2013-04-11 17:26:11.000 iTunes[7654:22b13]: radio-error = 512
2013-04-11 17:26:11.000 iTunes[7654:22b13]: radio-error-string = 'Communication failure'
2013-04-11 17:26:11.000 iTunes[7654:22b13]: fatal recovery mode radio error
2013-04-11 17:26:11.000 iTunes[7654:22b13]: radio errors detected; stopping
2013-04-11 17:26:11.000 iTunes[7654:22e17]: iTunes: Restore error 23
To my recollection there's not a fix for this?
Am I right?
Thanks,
Steve
Score -1
Add a comment
1 Answer
stek2009, Error 23 is a baseband/radio error. It occurs when an unlock / baseband flash fails. Check on here and see if that will help, otherwise you may have to replace (reball) the baseband/radio IC. Hope this helps, good luck.
Add a comment
Add your answer
Steve will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 764
