Kindle Fire Reassembly After Digitizer Replacement
The "Ifixit: Installing Kindle Fire Front Glass Panel" guide specifies assembly as being disassembly in reverse order. This make sense, but there are a few steps regarding tape and adhesive that are removed/disturbed during the disassembly process that I'm wondering how to reinstate upon assembly.
Please reference the guide when answering the following questions:
Step 3
It looks like I disturb the glue holding the battery cells in place. What am I supposed to use when I reassemble to hold the batteries in place?
Step 6
There is tape that I must peel back to access and remove the speaker connector to the motherboard. Upon reassembly, should I reuse this tape or should I replace it with something comparable? If the latter, where do I purchase this?
Step 12
There is adhesive below the motherboard, (perhaps for heat dissipation?). What do I use to reinstate upon reassembly?
Step 14 and 15
There are two pieces of tape retaining the ambient light sensor cable. Again, should I reuse or replace the tape (and with what)?
Step 17
There is adhesive below the mid-frame. What do I use to reinstate upon reassembly?
Please help!!
Add a comment
