Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2940 Questions View all
iPhone 4s Speaker not playing/ working intermittently
The speaker/ volume control is not working on my Iphone 4s. The headphone jack works just fine and some sounds (initial unlock click, alarms, and setting ringer volume through settings) play indicating speakers themselves are semi-operational. When I select the volume buttons either nothings displays or it says "volume" with no indicator bars. I have tried restoring with no change. Any ideas what is happening here?
Also, it was dropped in a toilet in December, but had no problems afterwards. I placed in rice for several days and it has worked perfectly until today (early April).
Thanks for any advice in fixing this issue!
Add a comment
Chosen Solution
you could try clean the dock connecter with a tooth brush or its not that expensive to repair the dock connector your self
iPhone 4S Speaker Enclosure Replacement
Score 1
Comments:
Thanks for the feedback. Yesterday the headphone jack also started cutting out intermittently. I have to unplug the headphones and re-plug them again to make it work. Does this indicate a different problem as they are 2 separate parts? It does it using different applications, so is not specific to one app being used.
Thanks!
by
i had the same problem it was when i plugged the phone into dock music station and after it would fart about and also the volume on the screen would vanash. all i did was clean the dock with a tooth brush and it worked
by
Add a comment
clean with isopropyl alcohol.
Add a comment
Had the same problem. Managed the problem by a thorough cleanse of the dock connector equipped with a surgical headlight, loupes, micro forceps, fine gauze and alcohol. Don't forget the connectors at the sides of the dock.
Add a comment
Add your answer
Jen Landry will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 14
All Time: 12,549
