Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2946 Questions View all
iPhone 4S Water Damage/Teardown Help Requested
I accidently submerged my iPhone 4S in the washing machine for about 30 seconds.
Can someone please explain how to remove the metal frame covering the flash chip to clean any corrosion (I've removed all the EMI shields already)?
I see the frame removed in the ifixit teardown, but not how it was removed.
Thank you,
Jason
Score 1
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Most Helpful Answer
Hi jason5, thanks for your question!
Following our iPhone 4S Display Assembly Guide should get your iPhone nearly completely disassembled. Once you have everything opened up, you'll want to follow the cleaning steps outlined in our Electronics Water Damage page.
Good luck!
Score 2
Comments:
Hi Andrew,
Thanks for your reply. I was able to follow your guide to get the logic board out. I then proceeded to remove the EMI shileds. There was some corrosion on the leads to the A5 chip. I'm getting errors related to the Toshiba flash chip and am wondering if there is some corrosion there. However, the shield over this chip appears to be secured much better than the rest. I'm wondering how you removed this in your teardown.
Thanks,
Jason
by
I'd have to see a picture of the shield to be sure I'm giving you the right advice, but in general the tighter shields are often soldered on, and the only way to cleanly remove them is by desoldering.
You'll need a clean, fine-tip soldering iron, a small sharp tool like a sturdy pick (I use one of the automotive picks), and a small vice (or three hands).
Heat up the iron and put a bit of solder on the tip to improve its heat conductivity. Run the tip along the solder pads on one side of the shield, being careful not to touch any components surrounding the shield. While heating the solder pads, wedge the pick into a corner or hole in the shield (being careful not to go too far and damage the chip inside) and gently pull straight up. You need to apply just enough force the shield will come up without deforming it. Be careful with this part.
Once the first side pops up, work your way around the remaining sides, melting and pulling with your pick.
by
Thanks again Andrew. I'm assuming this is one of the tighter shields, but I've added a picture of it to my original post. I think this one might be out of my league as far as such fine desoldering goes. Would an ultasonic bath in alcohol be out of the question to get at any corrosion that might be under there?
by
some people use a scalpel to cut the shield along the upper edge rather than desolder.
by
That is the sort of shield we'll desolder for a teardown, but if you're not confident in your abilities, an ultrasonic alcohol bath might not be a bad idea. If you're not too worried about destroying the shield, it is possible to clip the legs with fine-point wire cutters—just be very careful not to cut any deeper than the legs, or you might damage the chips inside.
by
Show 1 more comment
Add a comment
Add your answer
jason5 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,213
