Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
iPhone 4g not charging after connecting a different wall charger!
iPhone 4g not charging after connecting a different wall charger.Does their any charging fuse problem?Computer doesn't detect it either.
Score -1
Add a comment
1 Answer
Most Helpful Answer
Jami, it actually sounds more like a dock connector issue. Replace that first. Use this guide for it. The part is available right here. You could check the USB power fuses as well as check the USB Power IC and see if it looks charred.burned etc. Hope this helps, good luck.
Score 2
1 Comment:
I checked all three things but in vain!I also connect the same charger on my iPhone 3g and it is completely dead now:(.
by
Add a comment
Add your answer
Jami will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,374
