Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7 Processors
568 Questions View all
I'm swapping 120 SSD for 256 SSD.
Do I need more than a normal back up of current hard drive? Will software, OS, etc. work if moved to new hard drive?
Any potential problems to worry about?
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Chosen Solution
If you can mount your SSD into a USB external case or SATA to USB cable harness you can clone your current SSD (or HD) over to it.
Doing it that way you don't really need a backup as your current SSD (or HD) will be your backup.
You can even use the Boot Disk preference setting to test out your SSD before you open the system to exchange out the drives.
Score 1
Add a comment
Most Helpful Answer
Normal backup should be fine. You'll have to boot from an install disk to format the new drive, install the OS and then use Migration Assistant (in the Utilities folder in Launchpad) to restore information to a new computer or HD/SSD.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Add your answer
Mark Porro will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 170
