Repair information for the 7" Android tablet by Samsung. Fixing this device is straightforward, and requires only common tools. The Samsung Galaxy Tab is an Android-based tablet computer produced by Samsung. The 7-inch Samsung Galaxy Tab is the first model in the series. It was introduced on September 2, 2010
137 Questions View all
Doesn't turn on and says to download custom OS.
One day my Samsung Galaxy Tab 7.0 turned off, and I tried holding down the power and volume buttons. It said it needed to download a custom OS or press down on the volume button for restart. Every time I go to restart it just stays at the "Samsung" screen and when I go to download, it will just stay on the screen of the Android character. It says it's downloading, but it will just stay like that until it turns off. Please help.
Score 338
Comments:
mine is the same, just dont no what to do, there is no help, all because of a stupid update, which i never wish i had done , help needed please
by
did you lose everything you had on your phone after you downloaded the custom os?
by
Mine did too idk what is happening
by
mine too.and it a new phone i got two month back.i just dont know how to tell my dad.
by
i havesame problem no so wat should i do to make my samsung grand to be ok
by
Show 51 more comments
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Chosen Solution
You want to press VOLUME UP, power and home buttons. Hold until you see Samsung then release. You are booting up in download mode by mistake.
Score 155
Comments:
Thank you so much for your answer, it worked :)
by
Won't do anything but if I push volume down the warning comes on. How long do I need to hold it?
by
Worked, thanks!
by
Omg thanks sooooo much it worked
by
I did that but it said no command
by
Show 77 more comments
Add a comment
Our phones aren't exactly similar so. What works for the other might not work for you. I have a Samsung Galaxy Tab 2 10.1. Note that what I have is a TABLET, not a phone. According to the Samsung's site Help category,
in order to go to the selection of Resetting (i.e., Wipe cache partition, factory reset, reboot system) I must hold the POWER BUTTON & VOL. UP together.
However, holding them 'caused my device to head onto "Custom Os installation".
I figured out, what if I try holding the vol. down instead of vol. up?
Now, that was when it went to the selection of Resetting.
So, in simpler words: Try changing it up.
What worked for me:
Hold POWER BUTTON + VOL. UP = CUSTOM OS INSTALLATION
Hold POWER BUTTON + VOL. DOWN = ANDROID FACTORY RESET SELECTION
Remind you, this is what worked for my Samsung Tab 2 10.1.
Score 32
Comments:
I have a Samsung Galaxy Tab 3 but my volume down button is bust
by
i have a galaxy tab 3 and none of these have worked..i disconnect the battery for a few minutes then charge battery up to 100% it still wont switch on unless the charger is connected..as soon i unplug it from the charger it goes off then i have to repeat it all again.
by
@Betty Swollocks. You need to replace the usb connector module on your Tab 3. It's the part on your phone which receives the input from your charger. From the outside of the phone, you can only see the little mico-USB female input jack. But the phone has to be opened and taken apart. There's an entire charging module at the bottom of the phone which must be replaced. Not sure what it would cost where you are, but it should not be more than $30 for the part, plus add labor charges.
by
Well done yasmien019 ! You have to use the opposite volume key....then it allows you the choices needed to wipe the partition. Well done!!!!
by
Thank u so much yasmine, u really solved a big issue for me. this error occurred in my samsung s7 edge. it is very new phone and it happend suddenly but now its working according to your way. Thank u so much
by
Show 12 more comments
Add a comment
Try holding the power button until it powers down (more than ten seconds). You've booted into download mode. Once powered down, plug it into the charger and leave it alone for a few hours. Then attempt boot. Let me know what happens.
Score 11
Comments:
My Samsung i997 infuse 4
Here's a problem I help me please.
Warning!
A custom OS can cause critical problem in phone and installed applications.
If you want to download a custom OS, press the volume up key.
by
It's volume up, not down. Volume down is for installing custom roms. Hold volume up, home, and power.
by
What's d solution for d question above?
I use galaxy tab 2.10.1 n hv same custom os issue n it restarts n stays on d Samsung screen until power drains n same continues evn after again restating it.
by
Mine does the same. It is a galaxy Note 10.1. Took it to our "Gadget Tech" guy and he couldn't even fix it. Tried to restart the operating system, but no go. It must be a really bad problem with Galaxys.
by
i have samsung galaxy s duos . and i am also stuck on downloading process. i wanted to know that what exactly is downloading
by
Show 11 more comments
Add a comment
Hold the power button + volume button down + home button all at the same time
Score 4
Add a comment
if you held home volume up and power and it said download custom os then shut it off again and hold volume down home and power
Score 4
Comments:
I think it's that the volume buttons are different on this tablet
by
THIS IS THE SOLUTION! WOW Thanks you so much! I felt myself really bad because I got those options below. But this Volume Down haha worked! thanks!
by
I did that but it still had me download it, but now my galaxy note 5 has been stuck on the downloading screen for 12 hours straight and I need to know how to fix this
by
I have a Galaxy Samsung Tab E it was doing that thing with OS download. Can anyone tell me8 how long the download takes? Thanks
by
Add a comment
remove the battery this will reset your phone
i hope this help you out.
Score 2
Comments:
Will this delete everythig though??
by
Add a comment
on my note 4 this happened when in recovery mode i selected reboot to bootloader, to fix i went back into recovery mode and selected reboot system now instead, worked fine
Comments:
I tried rebooting but my droid says NO COMMAND. I can't do anything to my galaxy s4 its stuck on the globe when restarting and stays like that. so when downloading the OS do I need my sims card in it to get internet?
by
it's possible the internal NAND is corrupted, in which case downloading a new OS onto it won't fix it, nothing will short of a logic board replacement
by
Add a comment
Open the tablet up and disconnect the power cell for a few minutes. I was also suck on the downloading screen and after I hooked the power cell back up it started as usual with no problem.. hope it works for you as well!
Add a comment
Try this it worked for me. Take the back off of the phone so you can remove the battery. Start the phone. When the window comes up to download the OS app. Push the volume up key to start the download. Let run for 10 seconds then remove the battery and keep it out for a minimum of one minute. Put battery back in. Before reassembling the phone. Start it up. It should come on and not be in safe mode. May have to try again. This worked for me. PS. If you shut down. You will have to do this again.
Comments:
Thanks for the post it worked
by
Add a comment
I have a problem.
My Samsung Galaxy Trend 2 lite is lock forever, unless the keyboard is working. When I press Volume Down + home + power, I get a custom OS download choice and I need a to download a OS or not?
Now there is a real problem.
I cannot access factory reset nor could I get a recovery options either.
I tried doing what people did and their methods doesn't work for my phone.
ANY OTHER METHODS?
Add a comment
It requires internet to download operating system
Comments:
In my Samsung Galaxy s4 mini, a custom os window appears but not restarting
by
Add a comment
In some Samsung Galaxy models have the options to enter the recovery mode modified. In my case instead of being volume down + home button + button on, it's volume up + home button + button on. I saw that some license companies modify it to be vol down + vol up + home button + button on, and sometimes without the home button. All possible attempts must be made until the correct one is given.
Add a comment
I have a problem with my Samsung note 5 when i woke up a few days ago it would not turn on so i put it on charge and not it is going to the logo page that's it tile today it showed a Warning A custom OS Screen i then tried to hold all the buttons down ( home.power,volume,buttons) that did not work it then showed a Maintenance boot screen i can not move the button down to change to a different chose pick on that screen then it showed a installing updates but i never allowed it to update please help me i tried everything. is there any way to fix this
Comments:
If you are on the download page then all you do is hold the volume down+power+home button for a couple seconds and it should go black then turn on normally
by
Did you find a solution?
by
Add a comment
Thank you. Very helpful
Add a comment
Add your answer
Courtney will be eternally grateful.
Past 24 Hours: 260
Past 7 Days: 1,821
Past 30 Days: 8,016
All Time: 548,416
