7.9 inch display iPad Mini, with 16, 32, or 64 GB of storage.
672 Questions View all
iPad Mini touch replacement went really really bad.
I changed an iPad mini touchscreen, not first time doing this.
Well the thing is that everything went to s#!t.
My standby wake button doesn't work.
My touchscreen stopped working. i even tested another touchscreen with the little connector board already soldered and didnt worked either. Then i tested both touchscreens and worked properly on a different iPad Mini.
The battery is at 78% and im getting the full charged icon.
It is restarting itself every 5 to 10 minutes.
I was able to perform a restore via itunes, but the issues persists.
I disconnect and reconnected the battery, the issue persists.
Any help, please!
Comments:
Did you install the flex cable correctly? You'd better ask professional to help you find out the problem.
by
Add a comment
1 Answer
Chosen Solution
I had the same problems with mine ipad 2 3g
I had damaged the antenna's, after replacing them the problems where solved.
Add a comment
Add your answer
Robert G will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 1,172
