Fix Your Stuff
Right to Repair
Store
2.26 or 2.4 GHz / White plastic unibody enclosure
749 Questions View all
I think my multi-touch trackpad has sunk?
Hi
my MacBooks trackpad has sunk...twice... and i think its got to do with a bracket or some structure that keeps failing.... any ideas
Add a comment
SKIP THE UPGRADE
Save by fixing with an all-in-one kit.
Shop iPhone Fix Kits
SKIP THE UPGRADE
1 Answer
Most Helpful Answer
possible is almost everything
Teardown
look at step 7 - thats where you can see the trackpad - warranty ??
Score 2
Comments:
There is a screw on the underside that is responsible for depth, as well as two small brackets that hold it in place. Definitely take it in to an Apple store to get them to fix it, as it is still under warranty. If they won't, use the link provided by Markus Weihler to tear it down to step 7 and check out those brackets and the depth screw.
by
Add a comment
Add your answer
Max will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 3
All Time: 4,062
