Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
How do I fix iPhone 4 'Error 2001'?
Hello, my iPhone 4 went into recovery mode after the Apple logo kept going on and off but would not boot up fully. I get the plug into iTunes logo and when I go into iTunes to restore it, it gives me 'Error 2001'. I just called Apple and they said it is a hardware issue. It is not under warranty anymore. What part could be causing this?
Score 6
Add a comment
Most Helpful Answer
Based on the information found here, it sounds like replacing the battery wil solve the problem for you, and you can find those batteries right here.
iPhone 4 Battery Image
Product
iPhone 4 Battery
$11.99
Score 5
2 Comments:
replacing the battery worked for me! i had the exact same issue. Thanks!!!!
by
worked for me also! Cheers!!
by
Add a comment
Replacing the battery not work for me, any suggestion??
1 Comment:
Hi,
I am having the same problem! Did you ever find a solution?
Thanks
by
Add a comment
I have moved the whole logic board to a different chassi and I still get 2001 error
Add a comment
This problem is probably related to the battery. I had the same problem, when I unplug the phone, it stops working. I also had this error 2001 when trying to restore my 4s.
Add a comment
100% best solution!!
It is due to battery, but no need of replacement...
Yes, just ask in any mobile shop to put charge to your battery externally..
Now try inserting battery and restore will be successful!
Enjoyyy!!!
Add a comment
Is there anyway to charge the batter at homes without going to a shop? (I have the same problem)
1 Comment:
i'm sorry, with our cable it won't be charged. So please try to charge your battery in any other way. The only thing is to charge your battery... do not pay for any new battery.
by
Add a comment
You're the only person that has to do that
1 Comment:
The best way for my family to come out and get my hair is done
by
Add a comment
How to Connet network of sprint
Add a comment
Add your answer
Josh K will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 16,278
