The Kenmore Elite HE3 is a washing machine by Kenmore.
538 Questions View all
Is this machine heavy, or will it hold water after washing?
also why does it not empty after washing clothes all the way. the drum is empty but you can hear the water inside the machine. and after a while it stinks. and we use tablets and that sometimes don't work. are they made to hold water?
Score 1
Comments:
thank you so much for your answer it worked out perfect.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
Billy, here are the specs
Dimensions:
Weight (lbs.):
245
Height to Top of Cabinet:
38
Width (in.):
27
Depth with Door Closed (in.):
31.5
As for retaining the water, the only place, since you already checked the tub, would be by the water pump. Remove the bottom panel and drain/change the filter. Hope this helps, good luck.
Score 2
Add a comment
wont spin therefore wont drain water
Comments:
what have you tried to fix it?
by
Add a comment
Add your answer
Billy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 21
All Time: 810
