The Kenmore Elite HE3 is a washing machine by Kenmore.
668 Questions View all
How do I drain the water out of the machine?
Is their a way to drain the water out of a HE3T washing machine before moving it ?
Score -1
Add a comment
1 Answer
Chosen Solution
BILLY, I would remove the drain plug from the filter at the water pump.
1. Take off the lower front panel.Remove the bottom front access panel just remove the 3 Torx screws on front bottom of machine. Slightly lift the panel and pull the bottom towards you
2. Turn the pump filter cover counter-clockwise by hand and remove. Place a bucket or pan underneath it since you will get the water spilling out of there. Removing the filter should remove all water from your washer.
Score 1
Add a comment
Add your answer
Billy will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 3,495
