Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Questions View all
Question Closed
My iPhone4 does not charge
after i solder iphones power terminal
to the 4 pads who seems intact
iphone does not charge .also keeps
booting ,sometimes does not power on
by sleep/wake botton,how can test
the pads that they are ok,because
they look fine and firmly attached
to logic bord.
regards
1 Comment:
First thing you want to do is to measure the voltage on your freshly soldered contacts. It is possible that they are not making proper contact. Second, why did you need to resolder the contacts what happened to your phone?
by
Add a comment
1 Answer
After a while, the battery in an IDevice runs out of its limited charging cycles
Go to an apple store to replace it
2 Comments:
because battery terminal detacheded from logic board.
when i was removing battery.
by
i measured pads voltage all of them had
about 4 volts exept 3ed pad from top,if we
count them from top. is it normal?
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 310
