Repair information and guides for the fifth generation of iPhone. Model: A1387
2193 Questions View all
dead, can't recover, can't boot
On battery, the phone won't boot on. When I plug it into a pc, Apple logo appears then disappear, and itunes doesn't detect it. I put into DFU mode and its still attach to a pc, then itunes detect it and I can do the recovery, but while doing the recovery, error 1600 appears. Is it dead?
Score -1
1 Comment
the phone was drop, and I did a screen replacement.
by
Add a comment
1 Answer
Chosen Solution
, first issue sounds like a bad battery (hopefully, and not some charging circuit issue). I would replace the battery first. If after that you still get the iTunes error 1600, try this Get the latest version iTunes.
Check the USB cable is available and connect computer correctly.
Turn off the iPhone, and press the Home button until the USB cable connect the device.
Hold the Home button again until the "Connect to iTunes" message appears.
Release the Home button and restore required.
Connect the iPhone to PC via USB cable.
Run iTunes and backup your data.
Select "Shift+Restore", and then select the latest firmware from computer.
A message will pop up to inform you to erase and restore iPhone to iOS the latest cersion of iOS, and then click "Restore" to verify the restore with Apple. Also, check on here for more info. Hope this helps, good luck.
Score 1
2 Comments:
its weird when I plug the phone in to the wall AC, Im able to boot to the phone, but I can't use wifi
by
Did this phone get damaged in any way? Did this just start?
by
Add a comment
Add your answer
THANH NGUYEN will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 896
