iMac Intel 17" replace Display. correct ref. model (Second Hand)
Hello and Heeelp !
I have an Intel iMac 17 "2 GHz with the corrupted display. LM171W02-TLB2 Color LCD. There is only correct image on the right half of the screen, the other half is filled with vertical stripes.
I got a "new" screen LM171W02-TLB1 according to experts this reference does not require modifications like Unimac adapter LVD.
Screen boot in gray, then it appears Apple and a small circle below Apple, to stop the movement of this circle screen will to sleep (black) and I have not found how to wake her up.
Hibernate issue ?
pmset routines ?
The only way to make it work is to boot with the old damaged screen and once the system has booted, replacing the old with the new and works perfect.
But when you restart the iMac does not maintain the display parameters and returns to go to sleep.
Thanks
Ned F.
Additional Data:
Last login: Mon Mar 25 21:40:03 on console
Macintosh:~ xxxxxxxxxxx$ ioreg -lw0 | grep IODisplayEDID | sed "/[^<]*</s///" | xxd -p -r | strings -6
LM171W02-TLB1
Color LCD
Macintosh:~ xxxxxxxxxx$
'Hardware information:'
Model name: iMac
Model ID: iMac5, 1
Processor name: Intel Core 2 Duo
Processor speed: 2.0 GHz
Number of processors: 1
Total number of cores: 2
Level 2: 4 MB cache
Memory: 2 GB
Bus speed: 667 MHz
Boot ROM version: IM51.0090.B09
SMC version: 1.8f2
Serial number: QP70701PVUX
ATI Radeon X 1600:
Chipset model: ATY, RadeonX1600
Type: display
Bus: PCIe
PCIe channel width: x 16
VRAM (total): 128 MB
Manufacturer: ATI (0x1002)
Device ID: 0x71c5
Revision ID: 0x0000
ROM review: 113-xxxxxx-139
The EFI driver version: 01.00.139
Screens:
iMac:
Display type: LCD
Resolution: 1440 x 900
Depth: 32-bit Color
Integrated: Yes
Core Image: Hardware-accelerated
Main display: Yes
Duplicate: off
Online: Yes
Quartz Extreme: Compatible
Display connector:
State: There is no connected screen
Update
Thanks !
I think that is the only procedure that failure to perform. Obviously I do not have that DVI connector. I will look for a borrowed to try before you buy it.
By the way:
I ran some Flashing Tools and Patches and obtained that Main LCD Screen started normally.
Thus: Gray screen Apple Logo > soon a brief blinking > Voila ! !!
But there is a problem: ATI Memory amount it disappeared !!
Radeon X1600 Pro:
Chipset Model: Radeon X1600 Pro
Type: GPU
Bus: PCIe
Slot: Slot-1
Channel width PCIe: x16
VRAM (total): 5 MB
Vendor: ATI (0x1002)
Device ID : 0x71c5
Revision ID: 0x0000
ROM Revision: 113-B7710C-176
EFI Driver: 01.00.318
Displays:
Display
Depth: Color 32 bits (ARGB8888)
Main Display: Yes
Mirror: Deactivated
Online: Yes
