Second generation of Wi-Fi iPad, released on March 11, 2011. Model number A1395. Repair is difficult and will require heat.
301 Questions View all
iPad 2 Wifi picks up, but fades quickly.
Hello,
I have an iPad 2 (Wifi) 32 GB's and I somehow dropped it and the wifi doesn't really work as it should. It picks up a signal sometimes and then goes away, I'll be right infront of the router, but sometimes doesn't pick the signal up. I'm not really sure if I need to fix the wifi antenna or something else.
And if I need to fix the antenna, this tutorial will work fine? iPad 2 Wi-Fi EMC 2415 Bluetooth/Wi-Fi Antenna Replacement
Any help is greatful!
Comments:
Bump? Anyone have an idea?
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
The iPad 2 wifi setup is pretty simple. It is just one flex cable that runs near the home key at the bottom of the iPad.
That being said your issue sounds like the small connector that attaches for wi-fi signal has probably come loose. (you can see it closely @ step 43)
Unfortunately it seems you are going to have to open your iPad. The guide you have chosen is the exact one that you need to be able to fix this issue.
I highly recommend caution, go slow, pay close attention to the notes in each step. There are flex cables that are easily broken during the removal of the front glass.
What I would do is open it up, get yourself to step 43, and check to see if that connection is secure. Most likely it has come out or isn't seated properly after your unfortunate drop.
Good luck!
Score 1
Comments:
That's what I was thinking. I'm just kind of worried about opening the iPad myself.
by
Add a comment
Add your answer
SeanK will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 421
