iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Questions View all
Question Closed
Replaced battery on iPod Classic, Turns on but doesn't charge or sync
My iPod classic dint turn on or charge, so I replaced the battery. Now it turns on with the charge left in the new battery, but doesn't charge.
I tried in wall adapter and computer both dint work.
I also ran diagnostic mode and couldnt pass the USB_Detect test.
Please help me out !!
Add a comment
1 Answer
Chosen Solution
Rack, "couldnt pass the USB_Detect test." check the dock connector on your iPod. make sure there are no bend, broken or corroded pins. Also, try a different cable. The other issue with this model is the battery connector on the logic board. It does have a tendency of disconnecting from the board and eventually to break off. Hope this helps, good luck.
Score 1
2 Comments:
Thanks for the suggestion,
The cable is good, it works fine with my iPhone.
I see some discolor in the pins.
Is it easier to replace the dock connector port by myself, I don't really find self install-steps on the internet.
by
No, it is a royal pain. It requires fine soldering of 30 contacts plus two anchors. Then it is also a chore to find a replacement (I harvested from an old board) and to resolder it. It takes patience, the right tools and practice.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 421
