Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
952 Questions View all
Replaced battery on iPod Classic, Turns on but doesn't charge or sync
My iPod classic dint turn on or charge, so I replaced the battery. Now it turns on with the charge left in the new battery, but doesn't charge.
I tried in wall adapter and computer both dint work.
I also ran diagnostic mode and couldnt pass the USB_Detect test.
Please help me out !!
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
1 Answer
Chosen Solution
Rack, "couldnt pass the USB_Detect test." check the dock connector on your iPod. make sure there are no bend, broken or corroded pins. Also, try a different cable. The other issue with this model is the battery connector on the logic board. It does have a tendency of disconnecting from the board and eventually to break off. Hope this helps, good luck.
Score 1
Comments:
Thanks for the suggestion,
The cable is good, it works fine with my iPhone.
I see some discolor in the pins.
Is it easier to replace the dock connector port by myself, I don't really find self install-steps on the internet.
by
No, it is a royal pain. It requires fine soldering of 30 contacts plus two anchors. Then it is also a chore to find a replacement (I harvested from an old board) and to resolder it. It takes patience, the right tools and practice.
by
Add a comment
Add your answer
Rack will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 408
