Where is the imei stored on motherboard
Hi,
is someone knowing where is the imei stored on the motherboard? Is it writed on it? Is it posibile to see it if the motherboard is out of order?
Thank you
Hi,
Thank you
miguelin, for the 3G it's the chip labelled
NUMONYX
PF38F3050MOY0CE
On a 3GS, it's the
NUMONYX
k5d1257ACC
This chip performs more than just the baseband function. On the iPhone 4, everything is on the NAND, including the IMEI, serial number etc. These are stored in special partitions on the NAND. Check on here if you need to see that partition. So to answer your question, no you can not see if it is out of order unless it is properly installed. Hope this helps, good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 4,371
