Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Questions View all
Question Closed
Where are the power pads on the Logic board to start computer
Hi,
I read many informations here and on internet about how to start and test Logic board from my MacBook but haven't found anywhere informations for my modele : early 2011 MacBook pro a1297 i7 2.2ghz 17"
(water damage, Logic board cleaned and keyboard and start button probably dead...)
Could someone help me please ?
Tank you.
1 Comment
G'day there: I'm currently dealing with the same problem, the result of an unknown white coffee spill.
AAPL cancelled my warranty (18 months to run!) but I'm now free to, and have applied, a coating of an anti-corrosive which aslo serves as a moisture repellant (in Oz, RE-ACT was used, and there are others.) Which, if I had been permitted to do while under warranty, would have stopped damage. Actually, the spill only caused a couple of sticky keys, everything else was OK. I must be losing my touch,what with the pwr sw now U/S.
Anyhow, I too am looking for these power-switch bypass points on a MacBook Pro "Core i7" 2.2 15" Early 2011, MC723LL/A - MacBookPro8,2 - A1286 - 2353-1*, (et al - why do we putup with their impossible filing system?)
On my logic board there is nothing resembling twin pads, certainly none that this retired radio tach would care to short willy-nilly.
So, if anyone has a link to a 'MacBook Pro 15" early-2011, AAPL tech's manual', it would be most appreciated.
Cheers
Jen
by
Add a comment
1 Answer
Chosen Solution
Unless you've waited days (not minutes or hours) you can further damage the logic board if you do this while it's still wet/damp. The keyboard and track pad must be disconnected. On the logic board above the trackpad flex cable connector & below the hard drive flex cable connector there are 2 power pads to power it on. They are shiny, silver large and square. Only short these pads & not other pads! Do not touch other components.
If this answer was helpful please remember to return and mark it Accepted.
Score 1
2 Comments:
Thank you for your answer, but there's nothing that looks like this on this logic board (and nothing is written en it). I read on internet that some boards start with connecting pins 5 and 29 on the keyboard slot, but didn't succed to do it... have you heard about this king of logic boards ?
thank you
by
look here NOTE: shorting the power-on pads might not work if the keyboard still connected to the motherboard Also here
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,561
