Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3222 Questions View all
verizon to GSM hardware conversion?
is there a hardware conversion from verizon to GSM?
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
ken, not possible. CDMA is in no way compatible with the GSM, they are different standards altogether. So , you would need a different motherboard and a different frame, which then would require you to also get a different display assembly etc. With all that accomplished, you might as well get a GSM phone. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
ken will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 95
