iPod with water damage & white screen with no sound isues.
I know there are lots of water damage issues already, but my situation is specific.
The iPod was outside over night, in the cold wetness of a friend's driveway. At first it wouldn't even power on, but after a few weeks of sitting in rice, I've got it going. The sound works fine, and the screen is even registering my touch, but the white screen wont go away, although it has improved over time. Before it was streaky and I could see the water and bubbles inside it. Now there's only a small patch of pixelated streaks, and the corners are tinted yellow.
I'd like to know exactly what's wrong with it so I can have it repaired instead of buying a new iPod.
Add a comment
1 Answer
Chosen Solution
wendie, sounds like you need a new LCD. this is strictly based on your description. It might work better if you post an image. That way we can see what you see. You should also clean the iPod properly to avoid corrosion. Rice is a great first aid, but it does not prevent corrosion. Hope this helps, good luck.
Score 1
Add a comment
Add your answer
wendie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 214
