Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
830 Questions View all
The best why to give your MacBook a boost?
I have MacBook Pro with 2 GB 1067 MHz memory (everything is standard from shop). I am thinking about giving my computer a technical boost. Since I am very green in field of computers I wanted to ask you guys what you would suggest to do. Cost is an issue, but I am open to all ideas. My own plan was to buy additional ram, but what do you think?
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Chosen Solution
According to Mac tracker you can use 8 GB of ram in your computer. This should be a significant performance boost. The only other thing would be a larger - faster hard drive up to 500 GB or a SSD drive. If not running Snow Leopard consider updating your OS. Ralph
http://www.ifixit.com/Mac-Parts/MacBook-...
http://eshop.macsales.com/shop/memory/Ap...
And here are the guides to help you make the chages. Ralph
MacBook Pro 13" Unibody Repair
Score 4
Comments:
agreed +
by
agreed +
by
Add a comment
I had the same issue and upgraded to 4 G total. But it requires getting 2 2G Chips. Good luck.
Add a comment
will that fix too many spinning beachballs. i have only had my MacBook Pro for less than 6 months. Should i upgrade the ram? i have the standard 2gb. My hard drive is about 50 percent full mostly i think due to my 42gb in my itunes library. I have reinstalled the OS twice and the applications once. The spinning beachballs have reduced in number but still happening. i gpot a mac so i don't have to worry about these things happening.
please help
Comments:
De-fragmenting files and optimizing the volume helps a lot.
by
Add a comment
Add your answer
Kasper Harbo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,346
