The Motorola Droid RAZR Maxx is a version of the Droid Razr carrying a higher capacity 3,300mAH battery.
31 Questions View all
broken back glass over camera lens, droid Razr Maxx hd?
I have a broken back lens broken, need the part and how to fix it
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
After complete tear down of my Motorola droid RAZR M xt907, I used a heat gun to help loosen the glue on the back side of the camera glass. I then started pushing the glass from the inside outward with a pry tool. After peeling the remainder of the glass off and the glue tape I put the new glue tape on the phone and then the glass over the glue tape. The only thing you need to be careful with when using the heat gun is below the glass where the plastic coated cover where the phone serial numbers are.
Hope this helps.
thanks,
tstewart01fan
Update
Travis I got the replacement glass from www.etradersupply.com and here is the part number from their web site. Let me know if I can be of further assistance.
OEM Motorola Droid Razr M 4G LTE XT907 Battery Door Glass Lens
Item # ESMOT10184735
Comments:
This isn't an answer just a question for Paul, where did you get the replacement glass from?
by
Add a comment
Where did you get the adhesive tape i broke my glass part so found the part via you on the site..but they don't have the tape...what kind should i use or get..thank you do much
Add a comment
The Tape was included when I bought one. They said they all come with the adhesive regardless of the add. Etradersupply.com was very helpful.
Add a comment
My back camera lense was busted. My friend made coffee and spilled it on my phone and now I have coffee under the lense. I got half of it out, I just can't reach the rest of it. Do you have any suggestions for getting it out?
Add a comment
My Motorola Droid Razr M's back camera glass is broken. I'm searching for the part first and then go for its replacement. Does somebody know where I can get this part from
Add a comment
Add your answer
rdcarter will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 7,003
