2.26 or 2.4 GHz / White plastic unibody enclosure
634 Questions View all
Replace The Battery?
Afternoon all, please find my battery specs below.
Model Information:
Serial Number: 9G02404N9E1MA
Manufacturer: DP
Device name: bq20z451
Pack Lot Code: 0000
PCB Lot Code: 0000
Firmware Version: 0201
Hardware Revision: 0002
Cell Revision: 0158
Charge Information:
Charge remaining (mAh): 0
Fully charged: Yes
Charging: No
Full charge capacity (mAh): 0
Health Information:
Cycle count: 1076
Condition: Replace Now
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 12381
The battery obviously needs replacing, and I was just wondering, where could I purchase a replacement battery, and how would I go about fitting it ?
Add a comment
1 Answer
Chosen Solution
You would use the Guide for your machine. You can purchase a battery here, or from any other vendor. You should also purchase the recommended tools - every DIY job is easier when you have and use the correct tools.
If this Answer is helpful please remember to return and mark it Accepted.
Score 1
Add a comment
Add your answer
James Huntley will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 37
All Time: 6,416
