The sound is messed up
it sounds like the headphones are not plugged in all the way but they are. You can hear the music but not the words
is digital it should be all or nothing... are you listening to a karaoke or instrumental track?
Remember to return and mark as accepted the answer that best solves your problem.
Good luck,
N
clean the jack. you can also try to use a very fine screwdriver or similar tool to carefully bend the outer connection a bit towards the plug...
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,448
