Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 16 or 32 GB capacity / black or white plastic back.
1956 Questions View all
Why does vibrator not work after back case replacement?
Replaced back cover and once back together, everything appears to work except the vibrator. When I remove the screen to test the vibrator, it works when I flip switch to silent, but each time I put the screen back in, it no longer vibrates. I suspect the silence switch is getting shorted when I install the screen. Any ideas?
UPDATE: In further testing, I found the silence switch does not mute any sounds either.
Add a comment
Chosen Solution
Hi gatesmith,
I apologize for my delayed response.
Great that you have another 3GS available where you can use parts from. I recommend using the flex cable of the headphone/volume/silent-switch/power-switch of it and put it in your phone. Then I would check if it works.
In regard to using a multimeter: I haven't checked the circuit of the silent-switch yet (pin allocation). However, if you use the removed flex cable, you might be able to find the pinout for the silent-switch. Just trace the two circuits leading from the silent-switch to the connector. Then take the multimeter, put it on continuity test, and turn the switch. If the connection is still good, you should get a signal when turning the switch.
Another idea I would recommend is to visually check the immediate area around the connector on the motherboard where the resistors are soldered on (the connector is labeled as J1_AP ; bottom left). Are there any traces of a possible occurred burn visible?
Steffen
Score 1
Add a comment
gatesmith,
It is difficult to say where the problem is actually located.
But in any case, I would check the silent switch first. Remove the motherboard and check out that area (position of switch; flex cable; etc.).
Is there a way for you to test the switch for function in this open condition, for example with a multimeter?
Steffen
Comments:
Thank you, I could check it with a multi-meter. I found a connection I do not like the looks of. Fortunately, I have another 3GS which I now intend to further strip for parts. It would be nice to know how to check it with the multi-meter if you have time to explain.
by
Add a comment
Add your answer
gatesmith will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 203
