How to Replace LCD Flex Cable Ribbon for Apple iPhone 5
I ve recently opened my screen and the ribbon of LCD cutted.I found us spare part just the ribbon
how can i attempt to change it
you cant, you will have to get a new screen!
http://www.ebay.co.uk/itm/310505456829?s...
Please let me know if that component will be effective
the process to replace that cable is extremely difficult and the equipment and solvents required are expensive too (above the $800 Range). you must first separate the front glass from the LCD\Digitizer then de-solder the digitizer cable, then separate the digi and lcd. after that remove the epoxy holding the cable to the lcd then de-solder that, when that's done you will need optically clear adhesive to put everything back together.
Thank you so much for your answers Please let me know if just heating will separate LCD from digitizer Best wishes
Hi.i do have the same problem. While trying to repalce the outer glass the Digitizer ribbon has got cut out. I am not sure where to put it back or how to replace it. Could you please guide me.
I have same problem
Did u get answer?
The phones screen came off after a guy dropped it and he got mad and just ripped the screen off and broke all wires going to camera and screen if I bought new screen would those wires come with it????
YEs!!! If you but a preassembled screen it comes with it. Also you may need to buy another camera
hi
can you explain what is LCD flex cable, my nexus 6p now black screen, but the touch, vaibiration, sounds all work done, only the screen light.
please help me
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 35,695
3 Comments
Stentoumis Christos, could you please post a link on where you got just the cable from? The very first thing I would look at, is this guide. iPhone 5 LCD and Digitizer Replacement Then it depends on what the connector of the cable looks like.
by oldturkey03
That is an excellent find:-) from what the end looks like, it appears to be strict pressure fitting connector. Any chance you can take a close up picture of your LCD where the cable joins the screen?
by oldturkey03
Best wishes
by Stentoumis Christos
